User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Scale conversion engineering drawings
  1. #11
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ggunn View Post
    1" = 10' is 1:120 scale, isn't it?
    yes
    but they deal in feet
    there are 2 scale types
    engineers ":' 1:10 (1"=10'), 1:40, etc
    architects ":' 1/4 (1/4"= 1'), 1/8, etc
  2. #12
    Join Date
    May 2008
    West Chester, PA
    Posts
    608
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by t_van View Post
    I'm trying to understand scales on engineering drawings.
    I have a plan view drawing of a proposed electrical room on an 11''x17'' size sheet of paper. If the scale is marked 1/2"=1', is this the scale for the full-size drawing? What size paper is used for full-size drawings? How is the scale adjusted for 11"x17" paper?
    Unfortunately, the size of the paper has nothing to do with the scale. Are you sure 11x17 is not the original intended size?
    It's best not to guess any dimensions from a piece of paper that appears to be a reduced, full-size drawing. You can never tell how much it has been reduced. I recommend you get a copy of the architectural or structural drawing with some dimensions on it. ggunn has the best idea, but only as a last resort.
    An engineering firm I know paid an "errors and omissions" charge when a designer tried to interpret the scale of a civil drawing by guessing the width of the parking stalls. The scale was off enough that the lighting calcs were wrong and more lights had to be added.
    Alternate current
    Line to ground and ground to line
    Current alternates
  3. #13
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    10,438
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Here's what happens when the scales are mis-read.
    Cheers and Stay Safe,
    Marky the Sparky
  4. #14
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by K8MHZ View Post
    classic
  5. #15
    Join Date
    Jul 2017
    Western Grove, AR Newton County
    Posts
    36
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, that is correct. That portion of my reply is an actual copy and past from an ANSI quotation.
    Scaling is very confusing to many. The hardest part is measuring something on a drawing and converting that into real life dimensions. If the Drawing has anything that is dimensioned, carefully measure the dimension leaders then create a Multiplier to get the actual size.
    Auto CAD allows the user to import a "Raster Image" (a picture or PDF). If there is something in that picture that is a standard size like a Dollar Bill, a Quarter, or even Coke can, you have a standard for that drawing and measurements can be created. AutoCAD can't Snap to a picture so the user needs to draw a line from one side of the picture object to the other, then an AutoCAD Dimension can be placed.
    JimO
  6. #16
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,639
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jimo144 View Post
    JimO
    But if you can get a pdf with accessible layers and a known scale, you can use the PDF Import feature to bring it into AutoCAD at scale. Also, any drawing that you do over the imported pdf will snap to its features if you want it to.
    Imported bitmaps, e.g., rastered images, kinda suck; their features "fuzz up" when you zoom into them.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
