User Tag List
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Should the receptacle install come free with the TV?
  1. #1
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    2,151
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Recently I have been called several times for installing receptacles behind wall-mounted flat screen TV's. I gave them each the price and each thought the job too expensive and declined. I have the same issue with ceiling fan replacements.
    I calculate the price of every job I do the same way: trip charge + (estimated labor hours x labor rate) + (material cost x markup) + (rental costs x markup). I have no problem booking most jobs using this formula, but for some reason people think that hanging a ceiling fan or installing an outlet behind a TV should be much less expensive. I actually had one lady say "That's more than I paid for the fan!" Apples and oranges. Guess I should have told her not to buy cheap fans.
  2. #2
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,494
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    No, they shouldn't.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #3
    Join Date
    Jan 2008
    Raeford, NC
    Posts
    3,691
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Give a price on wiring a hot tub. They loose their mind. The salesman said it would only cost about $100.00. Well, get the salesman to wire it.
    Organized people are people that are just too lazy to look for their stuff
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,494
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ceb58 View Post
    Larry B. Fine
    Master Electrician
    Richmond, VA
  5. #5
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,076
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    I've had that and one worse. Lady told me the pool salesman told her only $100 for her pool!
    Granted it was an above ground but length of run, difficulty in getting power out of the house, bonding, permits, etc. $100 wouldn't even cover the material or permits.
    If you aim at nothing, you will hit it every time!
  6. #6
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,494
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Saying that stuff makes it easier to secure the sale.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  7. #7
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    6,141
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Coppersmith View Post
    I have always thought that dental work was to expensive, it's not like they are real doctors.
    Don't get bent out of shape folks I was only joking.
    It seems that what you think something should cost and what you end up paying can be much different.
    The 95% of people that you can't trust give the other 5% a bad name.
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,854
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Your method is sound. People are disillusioned as to what an installation should actually cost. As Larry pointed out they're usually given a low ball price by the salesman who sold them the product. If they actually told them that the $300 TV will cost $500 to install it on the wall there they want it they wouldn't buy it.
    Rob
  9. #9
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    1,023
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Dental work is too expensive because dentists have effective marketing.
    They're sensitive to the charges and they have implemented a propaganda push to let people know that they are real doctors.
    https://www.theatlantic.com/health/a...dicine/518979/
  10. #10
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,230
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I had an abscess in the back of my lower teeth a few years ago. My dentist takes x-rays and says to go see the oral surgeon because he doesn't do extractions and I had an impacted wisdom tooth. (So I affectionately call the oral surgeon "Dr. Yankem'" because every time I need a tooth pulled that's where I have to go.) Dr. Yankem' takes a look and gets out his scalpel. He says you're in luck because as soon as I use my scalpel your medical insurance takes over. So I told him to have at it!
    -Hal
Posting Permissions
  • You may not post replies
  • You may not edit your posts
