User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Clearance
  1. #1
    Join Date
    Oct 2015
    US
    Posts
    29
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Clearance
    Does the code requires workspace clearance for a meter base and HVAC condenser unit disconnects.
    I have a cuatomer who just fired their electrician and hired my company to finish/cleanup the mess. What I noticed is that the home was built as a new construction and the 2 AC UNIT outdoors were right in front of the meter base and the disconnects were installed behind them too. I'm at the last stages and before i order wire or try to finish up. Do you think there will be a problem?
    Sent from my SM-N920T using Tapatalk
  2. #2
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,041
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Meter bases are not required by NEC, POCO may have some rules on clearances, mine does.
    As far as your AC disconnects see 110.26 A
    Moderator-Washington State
    Ancora Imparo
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,854
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    All of the POCO's around here require clearance in front of the meter.
    The AC disconnect clearance has been argued here ad nauseum, IMO it is required. Here in NJ the State has decided it's not required so that's how they enforce it.
    Rob
  4. #4
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,623
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    Some places say you must have 110.26 clearances if the device has overcurrent protection in it.
    NEC is not all that clear in this regard. If you want to take it for what it says, you might say workspace is required for any junction box with splices within it, because one can test for voltage (examine while energized) in that box.
    I live for today, I'm just a day behind.
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,854
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    As I stated this has been discussed before but for an AC disconnect we all know that someone will be testing the disconnect while energized if there is a problem with the unit. Given the choice between popping open the disconnect cover and sticking your tester leads in there versus removing screws and the cover on the unit, 99 out of 100 will check the disco first. I've done it many times myself. IMO fuses or no fuses makes no difference.
    Rob
  6. #6
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,623
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I agree. I also have many times crawled into crawlspace and taken voltage readings in junction boxes or other enclosures. Another key word in the code is "likely"
    Still one of the worst code sections that the CMP seems to think is fine the way it is. Pretty sure people have tried to clarify it but is always rejected.
  7. #7
    Join Date
    May 2018
    Eden, NC
    Posts
    59
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I believe the opening statement of 110.26 covers it well. A j-box is not equipment. IMO
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,854
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Vince1971 View Post
    Depends on whose definition you use. The NEC has such a generic definition even a locknut could be equipment.
    Equipment. A general term, including fittings, devices, appliances, luminaires, apparatus, machinery, and the like used as a
    part of, or in connection with, an electrical installation.
    Rob
  9. #9
    Join Date
    Dec 2010
    Posts
    1,456
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    IMC has clearance requirements also.Name:  IMC 306.1.JPG
    The more they overthink the plumbing, the easier it is to stop up the drain
  10. #10
    Join Date
    Apr 2006
    Simi Valley, CA
    Posts
    8,495
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dkidd View Post
    That's talking about the condenser
    I can build anything you want if you draw a picture of it on the back of a big enough check.
    There's no substitute for hard work....but that doesn't mean I'm going to give up trying to find one.
    John Childress
    Electrical Inspector
    IAEI / CEI / C10
    Certified Electrical Inspector
Posting Permissions
  • You may not post replies
  • You may not edit your posts
