User Tag List
Page 2 of 15 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 149
Thread: another AFCI nuisance trip question
  1. #11
    Join Date
    Mar 2003
    Vermont
    Posts
    2,039
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Go GE AFCI's Bull....
    they rarely trip
    ~RJ~
  2. #12
    Join Date
    Nov 2008
    WA
    Posts
    386
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    well thats good to know jockey, because my next whole house change out has a GE panel
    which is good, because around here you can NOT use a breaker in a panel it is not rated for. that usually means a BR, so you cant put a square D into a C-H panel etc. they'll get you every time. i try to use a recep instead of a breaker on these for obvious reasons as well. less owner-monkied wiring to try to protect as well. but i'm sure using 3 afci recepts will take care of it as it will remove all wiring from the circuit. just hope the house doesnt burn down haha (slap face again). oie!
    The End of the World as i Knew it: 2012. I'm having my Doom's Day now.
  3. #13
    Join Date
    Mar 2003
    Vermont
    Posts
    2,039
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Bullhiemer,
    I've been installin afci's since my state jumped 210.12 in the '98 cycle, tried them all
    GE is one of two manufacturers that took the GFP out of their product
    Others up on UL1699 could probably explain it better than I could
    Bottom line, less call backs & sleep better
    wishing it for you as well
    ~RJ~
  4. #14
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,243
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Fortunately we are not on the 2017 here yet but I can guarantee you that when we ever do nobody is going to file to replace receptacles. Nobody does now.
    If I were you I would walk away from that kind of work if you insist on filing, you have to be losing money. If you could just go in and replace receptacles, but how much do you have to charge to cover the AFCI problems? No customer is going to want to pay for it so they hire a handyman to go to HD and replace the receptacles with what was there.
    This is getting so bad that there is going to be a revolt!
    -Hal
  5. #15
    Join Date
    Mar 2003
    Vermont
    Posts
    2,039
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    To be honest, the handymen are winning out on my turf
    ~RJ~
  6. #16
    Join Date
    May 2018
    Jamaica and london
    Posts
    1,301
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    but, here I am, a handyman, studying the codes as I have been required in the places I work to get certified in the code to do any electrical now... In UK it is Part P certification but still... after years of doing light replacements and switch repairs, have to go to the basics of an apprentice apparently just to earn my 14 grand a year..lol...
    Not complaining, because most of it is learning how to bend conduit, and such, stuff I always stayed away from... Now I might be able to do work, in about a year...
  7. #17
    Join Date
    Feb 2005
    South of Bawstin
    Posts
    1,262
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Last few AFCI trippin issues I had was neutral touching ground in the circuit somewhere.
    Found the problem and AFCI did not trip anymore.
  8. #18
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,694
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mopowr steve View Post
    Have had issues in the past with inductive kick-back from exhaust fans when they are turned off, this could be the culprit.
    Ive been noticing more and more exhaust fans coming with a capacitor across the leads to the motor to dampen this effect (I think)
    I have been seeing "ultra silent" fans with capacitors, but pretty certain they are PSC type motors instead of shaded pole motors is the reason they have a capacitor. The cheap fans are still shaded pole motors with lesser blower design.
    I live for today, I'm just a day behind.
  9. #19
    Join Date
    Mar 2003
    Vermont
    Posts
    2,039
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by shortcircuit2 View Post
    One could, if one wished, de-energize, disconnect , and meter and/or meg all the noodles to ground
    ~RJ~
  10. #20
    Join Date
    Mar 2003
    Vermont
    Posts
    2,039
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Adamjamma View Post
    Try 7-8 to be on one's own here
    & good luck Adam
    ~RJ~
Posting Permissions
  • You may not post replies
  • You may not edit your posts
