Results 1 to 5 of 5
Thread: 60 A or 100 A service for a condo...
  1. #1
    Join Date
    Jul 2018
    NYC
    Posts
    1
    Hi All,
    I have a buddy of mine whom is renovating a condo space within Nyc. Not certain of sq footage for size but believe it just a standard two bedroom unit already equiped with a single phase 60 amp service (220v). One electrican claimed they will need to upgrade the service 100a but yet another electrician claimed the 60 amp service is fine. Largest load is a split air unit 30a, range oven 40a and maybe a hot tube with standard convenice outlets, everything arc fault as described by electrican.
    More is usually better but at a cost, any suggestions as to what you would do, upgrade to 100a or stay with 60 a service?
    Thank you and any suggestions greatly appreciated
    John
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,314
    I have never seen an electric oven in NYC but I haven't worked there in 50 years. If so and without more info I would say 100 amps is needed.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    Oct 2015
    US
    Posts
    620
    Agreed I do a lot of work in NYC and I also say go with the 100. Pm me if u need more information or a 2nd opinion
    Sent from my SM-G950U using Tapatalk
  4. #4
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,342
    One other note, depending on the building many condos in NYC are fed with 1Ø, 120/208 volts.
    Welcome to the Forum.
    Rob
  5. #5
    Join Date
    Aug 2013
    New York, NY
    Posts
    475
    Quote Originally Posted by Dennis Alwon View Post
    Funny story: a friend of mine does AV design/install work in high-end apartments/condos in NYC and the surrounding area. He recently did a load study on a condo being renovated, and it included an electric range, oven, and dryer (which IS strange for NYC). The condo was on the 30th floor; anything below the 25th floor had gas, and above, all appliances were electric. The engineer for the building apparently didn't account for having to get the gas to the top of the 50-floor building, and no accommodations could be made to raise the NG pressure after the building was built.
    High-end clients were pissed, but the only viable solution was for the contractor/engineering firm to comp everyone above the 25th floor electric appliances. Oops.
    SceneryDriver
Posting Permissions
  • You may not post replies
  • You may not edit your posts
