User Tag List
Results 1 to 5 of 5
Thread: Dead ABB Drive?
  1. #1
    Join Date
    Dec 2016
    Royal City, WA
    Posts
    237
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Dead ABB Drive?
    One of my Dairy customers called me yesterday. The have three wells supplying water for the dairy. Well one has a 60 hp sub pump with a Yaskawa drive. Well two has a 40 hp sub pump with an Aquavar by Gould’s branded drive. It’s actually an ABB ACS550 with some custom programming for centrifugal pumps. Well three is a 10 hp sub pump with a Yaskawa. Yaskawa drives are probably the most used drive in the agricultural market, at least here in the Pacific Northwest. Have a couple of good distributors for them.
    Anyway, they called yesterday and said the 40 hp ABB wasn’t working. Ran out and looked. No display on the control pad. Verified power to the drive. Replaced the control pad with a new one today. Still no display. Anybody have any ideas or suggestions? Not much I can do if I can’t get the display to power up.
    Otherwise, they will get a new Yaskawa to replace the ABB. Don’t have anything against ABB, just a lot more familiar with the Yaskawa drives. My cost is less than $100 difference between them.
  2. #2
    Join Date
    Sep 2008
    UK
    Posts
    12,703
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dzboyce View Post
    It could be something as simple as a loose connection but I don't know how much time you would put into fault finding before the cost of a replacement drive would be the way to go.
  3. #3
    Join Date
    Jul 2006
    Posts
    8,391
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I’m fairly sure that ABB powers the electronics via a DC-DC chopper power supply tapped off of the DC bus. Last I checked (ASC500, the predecessor to the 550) this was a separate card inside of the drive and was replaceable, but it wasn’t easy to do it in the field. So I agree with Besoeker, replace it now and then see if it’s repairable by playing with it on a workbench at your leisure. If you fix it, there is always a market for used drives.
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  4. #4
    Join Date
    Sep 2008
    UK
    Posts
    12,703
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Jraef View Post
    Thank you kind sir. And I agree. Most I have dealt with are fed from the DC link. Including those we designed.
  5. #5
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,697
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When I've had this happen in the past with various drives, I've always just replaced them. Sounds like a good opportunity to throw another Yaskawa in there so all their drives are the same.
    You're in the same market I am up here in NE Oregon. Yaskawa is our preference, we have two sitting in the shop right now, but we've also done ABB and AB and come across a fair amount of those three as well. Although we have one local pump shop that's been selling Weg for a few years now.
    Yaskawa also has a higher ambient temp rating in their 3R enclosures than ABB does last time I checked.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
