User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: double pole single throw snap switch use.
  1. #1
    Join Date
    Nov 2003
    Roanoke, VA.
    Posts
    4,716
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can I legally use a double pole single throw snap switch to control lights with one side and use the other side as a dry contact (no voltage) to send an alarm that the lights are on?
    If no please give me the reference.
    Thanks!
    Sometimes I don't know whether I'm the boxer or the bag.
  2. #2
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,041
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What is the no voltage side, is it a power limited circuit?
    Moderator-Washington State
    Ancora Imparo
  3. #3
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,321
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The 'no voltage' wiring will need the same insulation rating as the lighting circuit wiring.
  4. #4
    Join Date
    Nov 2003
    Roanoke, VA.
    Posts
    4,716
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tom baker View Post
    As far as I know it will just be a wire that will complete a loop that will go to a group of alarm cables coiled above their cable ladder. I do not know what their intentions are.
    I assume there will be no voltage used.
  5. #5
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    10,438
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by qcroanoke View Post
    How can it work if there is NO voltage? There has to be some, or nothing would happen. Even 5 volts is 'voltage'.
    Cheers and Stay Safe,
    Marky the Sparky
  6. #6
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    2,998
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The way you state this, I would go with "no" as the default answer. To get to a "yes" answer the wiring must be installed as Class 1 wiring with all the requirements. (For purposes of argument think of that as being like power and lighting wiring. Simply add a RIB relay in the switch leg and use the contact from it $19 for relay and a few bucks labor.
    I know what I don't know, and I know where to go to find it!
  7. #7
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,271
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    The reference may be 300.3(C)(1) and art. 725.136
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  8. #8
    Join Date
    Nov 2003
    Roanoke, VA.
    Posts
    4,716
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 480sparky View Post
    That can be done, we usually use 3/22 300 volt insulation for alarm wiring but we can use 12 thhn just as easily.
  9. #9
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    2,998
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    and what is you power source. Having the right voltage insulation doesn't make the installation legal.
  10. #10
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,284
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks!
    in general the answer is yes. however, if the alarm side is an article 725 circuit there will be other considerations.
    hint - there are DP snap switches made that have a barrier between the terminals for the two poles.
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
