User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Old Dog, New Tricks
  1. #1
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    6,141
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Old Dog, New Tricks
    Yesterday I went on a service call to replace a speed control switch for a ceiling fan. Removed the old switch and went to find a replacement.
    Found what looked like an identical replacement . Terminals marked L, 1,2, 3 the same as old switch.
    What I didn't notice was in print at the bottom of the package. Dual capacitor switch.
    This will not work with a single capacitor fan.
    Had to go purchase and install the correct switch.
    It been years since I installed a fan switch ( normally install a new fan and that way you know it will work).
    I had forgotten that those switches look exactly the same as far as the markings. At least now I can tell people that I'm senile and not stupid.
    The 95% of people that you can't trust give the other 5% a bad name.
  2. #2
    Join Date
    Sep 2008
    UK
    Posts
    12,703
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by growler View Post
    Would it not have been less cost to replace the entire unit?
    I know, hindsight and all that.......
  3. #3
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Besoeker View Post
    replace the fan?
  4. #4
    Join Date
    Sep 2008
    UK
    Posts
    12,703
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Ingenieur View Post
    replace the fan?
    Shall we let the OP answer?
  5. #5
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    it just seems odd to replace the fan when only the switch is bad, that's all
    relax
  6. #6
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    6,141
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    That what I normally do. Fans are cheap and the labor to install is not that much. I could have installed a new fan in less time.
    The choice is not mine to make, I can only make suggestions, in the end it's up to the customer.
    There are a few people (very few) that don't like our disposable society and all the waste and want to repair rather than replace.
  7. #7
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    isn't the switch just a single gang wall switch?
  8. #8
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    6,141
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    relax
    Not really. By the time the switch fall apart the fans are normally a bit old (10-20) years. If the fan was a real high quality unit such as a hunter original then it's worth repairs because it can have many years of service left. If the fan was a $50 special from a department store it's probably near the end of it's normal life anyway.
    MY original post was to let people know to check for the correct switch before getting a replacement because the 2 switches will look exactly alike. They are different internally.
  9. #9
    Join Date
    Apr 2005
    Atlanta,GA
    Posts
    6,141
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    The speed control switch that's inside the fan housing that's operated by a pull chain.
  10. #10
    Join Date
    Jan 2016
    Earth
    Posts
    6,049
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    makes sense now
Posting Permissions
  • You may not post replies
  • You may not edit your posts
