Nutmegger
- Fairfield County, Connecticut
It just occurred to me, even though I've done dozens of these..
If the two kitchen SABC's are set up as a MWBC, obviously the home run can be done with a single 12/3, but after that, the circuit splits into two separate runs of 12/2.
What about the NEC provision that all conductors belonging to the same circuit must be within the same conduit or cable assembly? Doesn't splitting of the single multiwire circuit into two cables or conduits at the end the home run violate that rule??
