User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: help selecting inverters - one or two?
  1. #1
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,346
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    This is for my system I will be starting soon. I think I am going with 63 235 watt panels, that is 14,805 watts. Kinda an awkward number to string, maybe I can find a place for one more. I am definitely going with fronius inverters since I get a good price on them from my supplier and they do 1kv strings. I dont have software to calculate dc/ac ratio so I am just winging it (anyone want to crunch it for me? ) I am thinking a bit on the lower side since the array will be due south, tilt we be ideal (34 degrees), and I am in the northeast where it is cool/cold. They make a 12.5 which puts me at about 1.2. Or I could go with 2 inverters and there are lots of permutations in the ballpark: 6+7.6, 5+7.6, 5+8.2.... Two inverters is about a $300-$350 increase but gets me 4 MPPT's. Think its worth the added cost?
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  2. #2
    Join Date
    May 2011
    Posts
    5,076
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by electrofelon View Post
    What are you getting paid per kWh? 12cents? If so my SWAG is that you'll about break even over the warranty period. The MPPTs, and not losing the entire system if one inverter fails, might be worth more than the ratio. Looked at PVwatts for you but their algorithm seems screwed up.
    Those inverters are not very efficient at 95 percent. Not much point in going below 1.05 on the DC to AC ratio. Might as well get close to that if you're going to bother, ergo the 6+7.6.
  3. #3
    Join Date
    Jun 2004
    Posts
    5,346
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jaggedben View Post
    I think its about 19,000 KWH/yr. There is a nice rule for my area, take DC system size in watts and mulitply by 1.25 gives you KWH/yr (assuming ideal tilt, no shading, etc).
    Just a WAG but guessing I will pretty much never clip at 1.1-1.15.
  4. #4
    Join Date
    Jul 2009
    Mesa Arizona
    Posts
    275
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  5. #5
    Join Date
    Jun 2004
    Posts
    5,346
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by BillK-AZ View Post
    Thanks, I tried that out, but I find their "string sizing tool" to be more useful. The configuration 4.0 doesnt allow 1kv strings, so annoying. It still baffles me how fronius likes to keep that their inverters do 1 kv strings a secret :
    Playing around with Pvsyst, Ill let you know what I come up with.
  6. #6
    Join Date
    Jun 2004
    Posts
    5,346
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Anyone familiar with PVsyst want to take a stab at explaining to me how you put in an inverter with two mppt inputs? I can't for the life of me figure it out. There is even an example in the help file but they lose me.
  7. #7
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,795
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    It's been a long time since I've dealt with PVSyst, but aren't there inverter specific parameter files one loads into PVSyst? It seems to me that if you were to load the parameter file for an inverter with multiple MPPT inputs you'd have separate ports for them.
  8. #8
    Join Date
    Jun 2004
    Posts
    5,346
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ggunn View Post
    It loads the inverter, and seems to know it has 2 unbalanced mppt's........however its setup such that there isn't just 2 fields that you enter your string data for each....seems you have to make a sub array for each mppt and......I just can't get it to work
  9. #9
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,795
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Sorry; that's about all I remember about PVSyst. I won't ask, but if you're using a hacked version of this pretty expensive software it might not be fully functional. If you're using it legitimately, why not ask their tech support for help? Back when I was using it I found them to be pretty responsive to questions.
  10. #10
    Join Date
    Jun 2004
    Posts
    5,346
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Good idea. Fyi they offer a free demo version for 30 days. I think even after that you can use it free with reduced capabilities.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
