fandi
- Los Angeles
Sorry I need an answer today. Thanks everyone.
Thanks for the reply. But I thought good engineering practices are Regulations, technical specifications and standards, are they not?Not engineering exactly, but be clear in what you say. For instance, avoid jargon and local names like calling for "a mossey" (I made that up) when the manufacturer calls the stuff strut or channel (Unistrut / Kindorf). If someone has to RFI part of a design, it wasn't clear to start.
When something might look funny, include an explanation, or at least a code ref., that it's really OK.
And remember the poor sods that have to build what you design . Try not to make their life difficult. Things like slightly up-sized conduit or strategically-located pull boxes can make things easier even when they're not strictly required.
Then you are going to have to be more clear about your question. I, for one, have no idea what you are asking for.Sorry I need an answer today.
sorry it's not my question. it's an interview question.The NEC, IBC, local reg's, etc are all required minimums, not design guides. There are places where we've argued that NEC minimums are not good practice.
However, if you can't communicate the design to the builders, it doesn't matter how good it is. (And I suppose the original question sort of demonstrates the point.)
Are you thinking of specific things like up-sizing wire for less voltage drop or using/not-using MWBCs?
