JimFromAustin
- Austin, TX
Hi Guys,
The garage is in a strange spot. Can't go underground to get to it, and can't use conduit to get there because there would be too many 90 degree turns. Really don't want to go overhead.
The only real choice is to run exposed cable on exterior of house, then under deck and then can make a short run of conduit from deck to the garage sub panel entrance. Shooting for 60Amps of usable service. The house has a flat roof so can't get into attic to run wire and it is single story, so no basement. Would need to run cable along top perimeter of house and shoot down the side at some point. Would like to protect that section with conduit if allowed.
Thanks for you help!
