User Tag List
Results 1 to 9 of 9
Thread: Ufer earth:
  1. #1
    Join Date
    Jul 2013
    Resting under the Major Oak UK
    Posts
    1,300
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ufer earth:
    Ufer earth:
    I didn’t want hijack http://forums.mikeholt.com/showthread.php?t=192662
    Ufer earthing is now in BS7671. In my early days in the trade as an apprentice we built a new substation. The rebar was cad-welded to 1 x ⅛ copper tapes around the foundations. In the above thread mention is made of clamps that can be used in place of cad-welding, has anyone got a link to these clamps?
    I can foresee a problem with this new BS regulation, mainly the builders wanting to get the slab finished and the electrician showing up two days later.
    BS = Male Bovine Exciment.
    The reports of my death are greatly exaggerated.
  2. #2
    Join Date
    May 2018
    Jamaica and london
    Posts
    1,304
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check with Rexel... know they have them in USA market and believe they can source them.
    Screwfix 80158 also works. I usually brush some vaseline over it, but it works.
  3. #3
    Join Date
    Jul 2013
    Posts
    1,300
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you
  4. #4
    Join Date
    Apr 2008
    SW Florida
    Posts
    573
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    We use NSI G-1-SDBR
    NSI Link: http://www.nsiindustries.com/catalog...lamps/g-1-sdbr
    Good for water, rods or rebar
  5. #5
    Join Date
    Mar 2007
    MidWest
    Posts
    747
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Compression Grounding
    You can also utilize compression type [ https://app.burndy.com/solutions/gro...sion-grounding ] this was the type I referred to in my previous post, even some local utilities are accepting these. Ironically after Don's post I went to discuss with a structural engineer and they mentioned they typically do not use the "weldable" re-bar. This from some googling if the sources are correct would be identified as such by the manufacturer and include a "W" in the listing indicating it is suitable for welding, it appears it all has to do with the carbon content of the rebar, I am no expert but found it interesting. I was also informed that structurally they account for the loss of strength in their design and selection, however I know of one site where they had to use multiple “shots” not sure what that does to the strength….
  6. #6
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,094
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I had in one of my grounding classes the electrician who made the ufer ground at the Satsop Nuclear Power Plant (never finished) He said it was a million cm wire with a 1000 cadweld shot. Lit the shot with a spark igniter taped to a long 2 x4
    Moderator-Washington State
    Ancora Imparo
  7. #7
    Join Date
    Feb 2003
    Minnesota
    Posts
    7,071
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tom baker View Post
    Boy Howdy ! ! Now there's an image !
    Another Al in Minnesota
  8. #8
    Join Date
    Jul 2013
    Posts
    1,300
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OK, I'm now officially confused.
  9. #9
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,744
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Tony S View Post
    About the 1,000 mcm conductor or the remote sparker?
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
