Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Conduit into DL
  1. #11
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,608
    Hard lid?
    Rob
    All responses based on the 2014 NEC unless otherwise noted
  2. #12
    Join Date
    Sep 2012
    NJ
    Posts
    2,099
    Quote Originally Posted by cdslotz View Post
    Bingo....now the OP needs to find out if MC is allowed or not
    MC is not allowed but like I asked since that's the case would "whips/tails" still be allowed even though it asked for full conduit?
  3. #13
    Join Date
    Oct 2015
    US
    Posts
    628
    Sounds like you need to submit an RFI. in NYC you could use mc/bx/ or fmc but your spec might not allow it basically your allowed to by code, but the spec is what your going off of
    Sent from my SM-G950U using Tapatalk
  4. #14
    Join Date
    Sep 2012
    NJ
    Posts
    2,099
    Quote Originally Posted by nickelec View Post
    I understand. But curious if you has spec that read like mine(full EMT) would fixture tails(FMC) be accepted. I know yes by code.
  5. #15
    Join Date
    Oct 2015
    US
    Posts
    628
    Full emt to me means full emt. RFI is your friend here
  6. #16
    Join Date
    Jul 2005
    Posts
    834
    Quote Originally Posted by mstrlucky74 View Post
    Is FMC listed in your spec? If so, what are uses permitted for FMC?
    Did you look in the lighting section of your spec?
    But if you use 4 sq boxes with whips and it is a sheetrock ceiling, then access panels must be provided for the 4 sq boxes.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
