User Tag List
Results 1 to 6 of 6
Thread: Pool Bonding Question
  1. #1
    Join Date
    Jul 2018
    CA
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am currently working on a pool that the Builder hooked up the equippotential Bond to the house service main grounding electrode via #8 bare copper. However the House service panel is about five to six feet from the edge of coping from the pool. Very old pool and house. the grounding electrode fell within the perimeter of the pool therefore he felt it should be attached. Is this an issue? Or should I detach the gec connected to the grounding electrode and drive a new rod establishing a new grounding system for the service? Thanks.
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,922
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Pools and gas stations are the two most uncommented topics. I don't think you need to detach anything and I would not drive any new ground rods.
    If you don't think too good, don't think too much.
  3. #3
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,963
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ActionDave View Post
    Uncommented topics????
    Lack of comments...
    Undocumented code...
    Not sure what you mean. Two definitions.
    "Electricity is really just organized lightning." George Carlin
    Derek
  4. #4
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,272
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Elky57 View Post
    There is not alot of info here so I will take a shot at it. I assume the equipotential bonding connects to the pool pump????? If so there is a connection thru the equipment grounding conductor to the main service which in turn is connected to the ground rod. Probably not an issue.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  5. #5
    Join Date
    Mar 2014
    McKinney, Texas
    Posts
    1,471
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Greetings,
    I will simply address the issue of the EBG connected to the dwellings GE. It is permitted to be done as described in 680.26(B) but not required.
    "An 8 AWG or larger solid copper bonding conductor provided to reduce voltage gradients in the pool area shall not be required to be extended or attached to remote panelboards, service equipment, or electrodes."
    Paul W. Abernathy
    Electrical Code Academy, Inc.
    CMP #5 and #17
    *All code responses are based on the 2017 National Electrical Code®[NEC®]
  6. #6
    Join Date
    Feb 2003
    Pennsylvania
    Posts
    2,599
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MasterTheNEC View Post
    Greetings,
    680.26 Equipotential Bonding.
    B (7) Metal Wiring Methods and Equipment. Metal-sheathed cables and raceways, metal piping, and all fixed metal parts shall be bonded.
    I agree with Dennis since the bonding is required to be connected to the source equipment grounding system there is no concern
    The OP question seems to indicate that the rod is driven 5 ft or less from the water edge of the pool. The question seems to be is this rod installed in the perimeter of the pool required to be bonded
    I would say yes
Posting Permissions
  • You may not post replies
  • You may not edit your posts
