User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
Thread: Service grounding
  1. #1
    Join Date
    Jul 2013
    Chicago,IL USA
    Posts
    58
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Service grounding
    Is it proper to connect a GEC for a service at more than one location?
    I see this all the time on residential services- two supplemental ground rods bonded together and tied to the meter can outside of the house and then a run from the panelboard inside to the water main. Shouldn’t the electrodes be bonded together and then tied to either the service disconnect at the panelboard inside or outside at the meter can? I thought tying GEC’s at two separate locations was a code violation?
  2. #2
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,966
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Lemme see if I got this right.
    GEC to two rods tied in at meter. Meter bonded to neutral.
    Another GEC to water line tied in at main panel. Assume Neutral and Ground are bonded together in panel, with 3 wire from meter to panel. Panel bonded to neutral.
    If so, unconventional but prolly okay.
    "Electricity is really just organized lightning." George Carlin
    Derek
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,985
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    It's very common and permitted.
    Rob
  4. #4
    Join Date
    Jan 2009
    Posts
    15,966
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    I should have said uncommon IME instead of unconventional maybe. Few POCOs I have worked with allow me to use the meter base.
    Derek
  5. #5
    Join Date
    Feb 2003
    Pennsylvania
    Posts
    2,664
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by rojay View Post
    i would think if given the option you would take the more direct path outside the building to earth
    i think the meter enclosure is a good optiion
  6. #6
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,985
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jumper View Post
    Must be a regional thing, around here the connection is not permitted in the meter enclosure by the POCO but I have seen this commonly elsewhere in the country.
    Rob
  7. #7
    Join Date
    Jul 2013
    Chicago,IL USA
    Posts
    58
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I see. The required bonding together of all electrodes is being achieved by their common connection to the service neutral.
  8. #8
    Join Date
    Jan 2009
    Posts
    15,966
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes. 250.24 is a player here also.
    Derek
  9. #9
    Join Date
    Jul 2013
    Chicago,IL USA
    Posts
    58
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Funny that you mention 250.24.
    250.24A1 is the section that I heard cited to claim that the grounding scenario in my OP was a violation
    The fact that the GEC connection is to be made at any accessible point from the load end of the service lateral to (and including)the neutral bus at the service disconnect was being used as an “either, or but not both” statement.
  10. #10
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,376
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There is only one GEC. The other wires are bonding conductors.
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
