Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Disconnects
  1. #11
    Join Date
    Sep 2012
    NJ
    Posts
    2,099
    Quote Originally Posted by infinity View Post
    That's how we would do it. The switchboard company would come out and measure the bus and fabricate what's needed. I'm guessing that they use methods that do not violate the listing of the equipment.
    So I guess it would be three pieces of detail one for each phase?
    Sent from my SM-G955U using Tapatalk
  2. #12
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,608
    Quote Originally Posted by mstrlucky74 View Post
    If it's on the line side of the service disconnect(s) it would need to be 4 pieces of detail because each service disconnect would require a neutral unless it were a 3 phase, 3 wire system.
    Rob
    All responses based on the 2014 NEC unless otherwise noted
  3. #13
    Join Date
    Sep 2012
    NJ
    Posts
    2,099
    3P4W..so the bus i jut bolted to the extg. bus bars?
    Also whats a bit weird is the con ed incoming is feeding ss#1 which feeds part of the MS-A board( I got that) but SS#2 & #3 and the blue school panel. What is ss#2 doing...looks like feeding the other half of MS-A but then ss #3 is feeding blue school panel. Something just doesn't look right with SS#2 & SS #3 and the blue school panel feed each other and how they work together.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	20986   Click image for larger version.
  4. #14
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,608
    I cannot read your attachments.
    Rob
  5. #15
    Join Date
    Sep 2012
    NJ
    Posts
    2,099
    Better? SS#1 is incoming from Con Ed
    Attached Images Attached Images
  6. #16
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,608
    Better?
    Not really.
    Rob
  7. #17
    Join Date
    Sep 2012
    NJ
    Posts
    2,099
    Not really.
    Sorry. Anyway...how do you attached bus bar to extg. bus bars....4000A in main switchboard? Bolt together?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
