Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: 3W Question
  1. #21
    Join Date
    Sep 2012
    NJ
    Posts
    2,279
    Quote Originally Posted by cdslotz View Post
    Nowhere in your post did you mention if this was an MC install, or hard pipe w/J-boxes. They layout would be totally different for each, but the number of wires as I described would be the same for each.
    MC but how would it be different between the two wiring methods? Thanks.
  2. #22
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    23,723
    There are 3-wire and 4-wire ways to wire three-way switches, depending on the juxtapositions of the switches, the supply, and the load.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  3. #23
    Join Date
    Jul 2005
    Posts
    867
    Quote Originally Posted by mstrlucky74 View Post
    If it was specified to be an all conduit/wire job with J-boxes with whips to fixtures, Then the travelers, hot, neutral, switchleg could be routed through the conduit from one switch location to the other.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
