User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Cable stuck - Chico
  1. #1
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    8,175
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Cable stuck - Chico
    Have a seal off at a waste water lift station, for a submersible level transmitter. At the seal off Contractor used Chico but no cotton. Dug the Chico out of the sealoff, Chico ran down the conduit and now the cable is stuck....not possible to access the conduit elsewhere.
    Suggestions? Long drill bit, solvent, mice?
    Moderator-Washington State
    Ancora Imparo
  2. #2
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,260
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    You could try pouring "Coca Cola" down the conduit and let it sit awhile.
    Or "Polywater" I've heard will sometimes work.
    If you aim at nothing, you will hit it every time!
  3. #3
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    7,052
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tom baker View Post
    polywater makes a stuck wire lube that might get it.
    not regular pulling lube, for unsticking glued in conductors
    pulled with yellow 77, 88 years ago.
    a lot depends on if he filled up the 90 at the bottom.
    i've unblocked pipes filled with slurry with muriatic acid,
    a piece of fish tape chucked in a drill, and rubber gloves.
    it is not much fun.
    how big a pipe, and what size wire?
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,399
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Mayhaps you can blow compressed air into the other end and manipulate the wires at the problem end.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #5
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,639
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    Pipe full of muriatic acid, compressed air...does anyone else see a potential problem here?
  6. #6
    Join Date
    Apr 2004
    Mission Viejo, CA
    Posts
    5,624
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I’ve only witnessed, but muriatic acid has worked in my experience - it does take a while and patience, but that’s the name of the game no matter what technique you use.
    "Bob"
    Robert B. Alexander, P.E.
    Answers based on 2017 NEC unless otherwise noted.
  7. #7
    Join Date
    May 2018
    Jamaica and london
    Posts
    1,306
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    just put a bag, full of holes of course, but filled with cotton balls, at the one end... air flows through, acid soaked by the balls... a few pieces of wire holding it in place or zip tie.. not as messy as it could be...
  8. #8
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,399
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gadfly56 View Post
    When was muriatic acid mentioned???
    Larry B. Fine
    Master Electrician
    Richmond, VA
  9. #9
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,296
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Post #3.
  10. #10
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,399
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    Post #3.
    Oh. That was suggested, not done.
    Larry B. Fine
    Master Electrician
    Richmond, VA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
