User Tag List
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 22
Thread: multiple current carrying conductors in a single racway (loading the boat)
  1. #11
    Join Date
    Jul 2018
    Northeast
    Posts
    10
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not to get off topic, but...
    What is this reference to "Full Boat"? A Conduit filled to capacity?
  2. #12
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    10,028
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by EverydayElectrician View Post
    Three hots and a neutral.
    If you don't think too good, don't think too much.
  3. #13
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,227
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Full boat or around here it's called a full set, however for us the use of MWBC's is waning with the common disconnect rule.
    Rob
  4. #14
    Join Date
    Jul 2005
    Posts
    925
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    amen...
  5. #15
    Join Date
    Sep 2012
    NJ
    Posts
    2,540
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jumper View Post
    If you are sharing nuetrals then you could get nine 20A circuits in a 3/4” EMT, derate and still use #12. I usually use stranded or use 1” EMT.
    9 hots, 3 neutrals, and 1 EGC. Code wise you can use the EMT as an EGC.
    Where do you get 3 neutrals for a MWBC? 1 per 3 ckts?
  6. #16
    Join Date
    Sep 2012
    NJ
    Posts
    2,540
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So you guys are running MWBC and using multi pole brkrs or handle ties? Even is spec calls for no shared neutrals?
  7. #17
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,227
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Depends, if the developer doesn't specify and wants the cheapest installation possible a bunch of handle ties are much cheaper than separate neutrals.
    Rob
  8. #18
    Join Date
    Aug 2017
    Hawaii
    Posts
    33
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wheredo you get 3 neutrals for a MWBC? 1 per 3 ckts?
    Yes. One neutral per A, B & C phase
    Depends,if the developer doesn't specify and wants the cheapest installation possible abunch of handle ties are much cheaper than separate neutrals.
    I still haven’t heard if guys are doing takeoff like this. Iknow you CAN figure it like this, but do you?
    Still looking for other tricks and methods to drive anestimate down…
  9. #19
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,592
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    I believe they make 3 pole handle ties.... 3- sp breakers and then the ties if you are worried about cost
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  10. #20
    Join Date
    May 2018
    Maryland
    Posts
    6
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How large are these jobs your estimating? I always assume 7#12's for my branch (where applicable) & i do this almost as you pictured, depending on how far they are apart. Doing calculations for this in my opinion is a waste of time; unless these are a good distance away from you BPB. Just my 2 cents.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
