User Tag List
Results 1 to 7 of 7
Thread: Vinyl Caution/Danger Tape and Energized Switchyards
  1. #1
    Join Date
    Aug 2018
    Oswego, NY
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Has anyone ever experienced or heard of a piece of loose wind blown vinyl caution/danger tape opening up a switchyard when the loose vinyl tape came in contact with two phases of the high side of the yard? I am drafting my organizations Barrier and Barricade procedure and I am considering prohibiting the use of vinyl caution/danger tape in energized switchyards given the vinyl tape has the ability to pick up dirt/moisture, thus becoming a conductor.
  2. #2
    Join Date
    Mar 2005
    Hampton, VA
    Posts
    354
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    PM me and I will forward you an example of an old utility guideline for demarcation of work in substations. They use plastic chains and signage.
  3. #3
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    10,031
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    How would it be possible for a piece of vinyl tape to short two phases? If it had enough mud on it to be conductive I can't see it being wind blown and if it did wouldn't it vaporize like putting a match to plastic film?
    If you don't think too good, don't think too much.
  4. #4
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    20,231
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ActionDave View Post
    It could certainly vaporize, but if it did, at medium voltage it could certainly leave an ionized air column that would maintain the arc for a significant period of time. (And in the worst case scenario might carbonize and coat the surface of nearby insulators.
  5. #5
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    41,098
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It maybe wouldn't be as big of a deal on say 15kV or less as it may be on higher voltages when it comes to what Goldigger mentioned.
    Then as mentioned there was concern of the tape having dirt on it over time, which can cause things to be worse if such a thing happened.
    I live for today, I'm just a day behind.
  6. #6
    Join Date
    Sep 2003
    Connecticut
    Posts
    257
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Vinyl caution tape? How 'bout Mylar?
  7. #7
    Join Date
    Aug 2008
    San Francisco
    Posts
    775
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by wtucker View Post
    It has been very well documented that Mylar balloons cause problems.
    https://www.youtube.com/watch?v=9anA66YB_6c
    https://www.youtube.com/watch?v=sRMTpsiY5gE
    https://www.youtube.com/watch?v=9Ve3aLFYgGA
    Am I in shape?? I get plenty of exercise pushing my luck!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
