Results 1 to 4 of 4
Thread: String Testing
  1. #1
    Join Date
    Aug 2004
    Irvine California
    Posts
    84
    String Testing
    What would be the easiest and most reasonable string tester. Looking for something that will store all readings IV curve and print out a report. Cost is always an issue however productivity is a must.
    Sent from my iPhone using Tapatalk Pro
  2. #2
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,708
    My cats like testing string. They are free to good home if you pay shipping. They don't store any readings, but they will sit in your lap if you are reading. They tend to push your book if you don't pet them.
  3. #3
    Join Date
    Nov 2015
    CA, USA
    Posts
    629
    Not a lot of choices out there. Seaward and Solmetric on the small end of the scale. There are testers that will let you test whole combiner boxes at a time and those are in the $30,000 range. Needed on utility scale projects.
  4. #4
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,538
    Unfortunately setups which can run an I-V curve on single cells or panels are in a different ballpark from those which can run the same curve on a full string, because of the much higher power dissipation required of the test load when working with a full string. Also voltages can exceed 1000V.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
