Results 1 to 2 of 2
Thread: Safety electrical warning signs/labels
  1. #1
    Join Date
    Jun 2005
    Posts
    8
    Greetings gentlemen, is there any references showing the type of warning symbols and labels which are needed to be posted on electrical switchgear, MCC, fence of transformer/substation, etc..
  2. #2
    Join Date
    Aug 2018
    Tucson, AZ
    Posts
    5
    It really depends what you are trying to accomplish.
    For general safety signage ("Danger, Keep Out" type and specific warnings for authorized workers) I would look to ANSI Z535.2. There may be others that are applicable, but I use ANSI signage a lot. If you look hard enough, there are a couple "draft" ANSI Z535 documents out there that don't require purchase. I believe ANSI is now making old versions available for web viewing, but can't find the webpage anymore.
    Here is a good, free guidance document for ANSI signage:
    https://www.ishn.com/ext/resources/R...Whitepaper.pdf
    NFPA 70E for arc flash labeling.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
