Results 1 to 5 of 5
Thread: Hospital work in Columbus Ohio
  1. #1
    Join Date
    Sep 2018
    Columbus ,oh Franklin
    Posts
    1
    Hello,
    My name is John. I have recently ran into a problem on a job at a hospital in Franklin county Ohio. My company was installing a new hot water plant and the controls for said plant were completely forgotten. I have been in a rush to complete to get plant running . My company submitted change order to engineering firm or designers. They have since came back with an excuse of why not to pay change order. They say that we did not have to run low voltage cable in conduit in mechanical rooms or up the 900 ft. Steam tunnel to 2 other buildings . They said it could have been free air application . Nothing in the old control systems even the phematics were in conduit. I have done many hospitals in past . I have never free aired low voltage in a hospital and there was a referral to the electrical code and spec conduit in mechanical rooms and steam tunnels. Does anyone know where and what code book or building guide lines this could be in so I have something to discuss in meeting on Thursday.
    Thank you in advance for your help
  2. #2
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,837
    Nothing in the Code that requires LV to be run in conduit so it's really a design issue. Although I agree with you in doing it that way, it is something that you should have specified in the change order. That way there wouldn't be a dispute if they approved it.
    -Hal
  3. #3
    Join Date
    Mar 2003
    New England
    Posts
    13,400
    If it's not in the building specs or state/local code, you are out of luck.
  4. #4
    Join Date
    Dec 2010
    Posts
    1,407
    Quote Originally Posted by Jsloan75 View Post
    If the controls work was not in the design (contract) documents, then they don't get it for free. It might be cheaper to run without raceways (which I wouldn't do), but it still is additional material and labor, which the owner needs to pay for. The temperature and humidity in the steam tunnels would require careful consideration of the wiring methods. You shouldn't design it. That is the engineer's responsibility. Ask for an an engineered design to quote.
    If I understand the situation.
    The more they overthink the plumbing, the easier it is to stop up the drain
  5. #5
    Join Date
    Mar 2003
    New York
    Posts
    1,244
    If it isn't in the bid it's extra. They can engineer it or if your Co. is capable you can design build, or hand them two cheap prepaid cell phones and tell them to have inhouse run it by hand! Reminds me of an old joke about the worlds oldest profession.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
