User Tag List
Results 1 to 2 of 2
Thread: Disconnect required for each pole for sports field lighting?
  1. #1
    Join Date
    Sep 2018
    Madison, Va
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Does the 2011 NEC require a separate disconnect for each pole light for a softball field. 6 lights on each pole with 1500 Watt Metal halide bulbs. Do the breakers in the distribution panel that feeds these poles need to be HID rated?
  2. #2
    Join Date
    Aug 2004
    Northern illinois
    Posts
    17,284
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Kenneth Smith View Post
    Take a look at 225.32 exception #3.
    If you are using the CB as light switches, I would say the answer is yes.
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
