Results 1 to 9 of 9
Thread: CSST Bonding
  1. #1
    Join Date
    Feb 2008
    Texas
    Posts
    897
    CSST Bonding
    I've never had to do this. Does anyone have a picture of what this looks like? I've seen some illustrations but am having trouble visualizing.
    Thanks!
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,589
    You can see it in this video
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    Apr 2013
    Sioux Falls,SD
    Posts
    293
    Is this not a mechanical code? Either way im pretty sure around here mechanical contractors bond it to the ufer ground or hire an electrician if no ufer ground is present.
    One other thing I don't believe many contractors install is the thin wall pipe around my area, they install the thicker wall flexible pipe due to no bonding required and a less chance of developing pin holes from near by lighting strike.
    Sent from my SM-G960U using Tapatalk
  4. #4
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,589
    Quote Originally Posted by Ohms law View Post
    This is a gas code issue, not a mechanical code. Some areas allow non-electrical contractors to do the bonding while others don't. BTW, the thicker walled stuff does not require bonding per the manufacturer's instructions however, the gas code still requires it, I believe.
  5. #5
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,060
    AFAIK, the black-coated stuff doesn't require bonding.
  6. #6
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,589
    Quote Originally Posted by 480sparky View Post
    So how do you get around the gas code that requires csst to be bonded? I have not read the code lately so I am not sure if they have an exception.
  7. #7
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,060
    Quote Originally Posted by Dennis Alwon View Post
    Mebbe it's not classified as CSST.
  8. #8
    Join Date
    Feb 2008
    Texas
    Posts
    897
    Thanks for the video Dennis.
    So, you either bond the regular black gas pipe or the fitting on the CSST?
  9. #9
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    23,377
    Are you referring to black-iron pipe or black-jacketed flex gas line?
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
