User Tag List
Results 1 to 9 of 9
Thread: Bends/Elbows
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,412
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bends/Elbows
    If you have a large job with a lot of large RGS conduit(3” +) and bends I assume factory(pre fab) elbows would be the way to go instead of field bending.
  2. #2
    Join Date
    Apr 2003
    Fort Collins, Colorado
    Posts
    1,748
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    IMO, yes. That would be one heck of a bender, tho.
    Ron
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,854
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    It depends, you will still need a large bender for offsets and kicks. Manufactured elbows could mean that you'll save on bending but then you may need to make extra threads in the field.
    Rob
  4. #4
    Join Date
    Mar 2003
    New York
    Posts
    1,711
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    We did a job for an out of state contractor who bid factory bends, after we counted how many (20 4"pipe duct bank than up into the control tower airport) extra fitting cost, they bought a bender.
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,854
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    For a large job you will need a bender. Short manufactured elbows are easier to spin on than an elbow at the end of a full length of conduit and have a shorter radius which makes the room required to spin them considerably less.
    Rob
  6. #6
    Join Date
    Sep 2012
    NJ
    Posts
    2,412
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sameguy View Post
    Takes longer to bend than install pre-fab elbow so you have to look at the material cost against added time/labor hours to install pre-fab elbow.
  7. #7
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,854
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    A pre-fab elbow is almost never the correct length which means that you will need to add some length of conduit to it. If it's less than a full length then you will need to cut and thread so you're not saving much labor. Sometimes bending the elbows is faster and cheaper.
    Rob
  8. #8
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    10,607
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    All I know is the guys that know how to use a bender, make those runs look like art.
    Tom
    TBLO
  9. #9
    Join Date
    Mar 2003
    New York
    Posts
    1,711
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Oh ok.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
