User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Questions about Lutron Caseta wireless
  1. #1
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,500
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    My brother called me about installing Apple HomeKit compatible switches in his house.
    The only wireless switches I sell/install are Legrand, and their HomeKit stuff is a few months away.
    Anyhow, he wants to do the Lutron Caseta switches; I’ve never used these. He read through some of their brochures and said it showed mechanical 3-way switches being used with the Caseta wireless switch at the load.
    My question is, is the Caseta switch able to determine the status of the load if you’re using mechanical switches in the mix? Seems like you would not be able to tell if the light is off/on via HomeKit unless everything is wireless. The Legrand RF switches I use require everything in the circuit to be RF capable.
    Brought to you by Carl's Jr.
  2. #2
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,500
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Well nevermind; if I’d spent 5 minutes on the Lutron site I could’ve answered this.
    But I’ll leave this for anyone that comes along with the same question.
    On the mechanical 3-way, you run a jumper from one traveler to the common, so the load can always be passed through from Caseta. And then the other traveler, from what I can see, is used to signal the Caseta, so when power is on or off on that traveler, it knows the position of the switch. If that makes sense.
    Page 23....
    http://www.lutron.com/TechnicalDocum...structions.pdf
  3. #3
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,564
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Why not just use a regular SP switch then? (I suppose the instructions are if you are installing the dimmer as a retrofit.)
    -Hal
  4. #4
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,215
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    I've put in several Caseta switches and most were when a 3rd switch was needed or needed in a different location. You replace one of the existing 3-way switches with the Caseta and rewire the other with a jumper as Brant read. You can then add a PICO wireless switch where ever else you need a switch.
    If you aim at nothing, you will hit it every time!
  5. #5
    Join Date
    Jun 2003
    Posts
    4,564
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I was going to edit my post above to add that after I wrote it I did read the instruction sheet and my head hurts. Fifty something pages cover every permutation of possible 3-way switch installations for the DIY.
    -Hal
  6. #6
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,198
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    This is noting new. The old X-10 companion remote switch worked the same way. One traveler fed through the companion to the source or load, and the other traveler allowed the companion to act as a remote controller for the main module.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  7. #7
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,215
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by LarryFine View Post
    But the X-10 had to have the switch and main module on the same service leg. Or at least the ones I wired did.
  8. #8
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    25,198
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Little Bill View Post
    I'm talking about hard-wired wall-switch modules and companion switches used to replace existing 3-way switch setups.
    Click image for larger version.
    You're referring to remote control of wall switches using PLC (power-line carrier) technology, for which a phase bridge was used to couple the legs.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  9. #9
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,215
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Guess you're correct on that. But I didn't use the bridge, I was using the Insteon switch that was compatible with the X-10.
  10. #10
    Join Date
    May 2018
    Jamaica and london
    Posts
    1,306
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I keep watching these to see if they end up with too many problems as it may be nice where I work at to be able to give customers two and three way switching from just one spot with the remotes wall mounted... when the cost comes down below what it costs to chisel out and install conduits and wires for the extra switch points will start getting them.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
