User Tag List
Results 1 to 8 of 8
Thread: Rapid shutdown
  1. #1
    Join Date
    Jun 2018
    Glen bunie, md, us
    Posts
    131
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Rapid shutdown
    I have 1500v (dc) inverter to 550vdc. The solar panel side 1500 vdc has 200 strings in parallel. It is enclosed by fence and solar panels on ground. There are no buildings and its used to provide electric power to 12.45kV ac utility grid. Does the solar system require rapid shutdown?
  2. #2
    Join Date
    Jun 2018
    Glen bunie, md, us
    Posts
    131
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have 1500v (dc) inverter to 550vac. The solar panel side 1500 vdc has 200 strings in parallel. It is enclosed by fence and solar panels on ground. There are no buildings and its used to provide electric power to 12.45kV ac utility grid. Does the solar system require rapid shutdown?
    Sent from my SM-G935U using Tapatalk
  3. #3
    Join Date
    Sep 2004
    Vancouver, WA
    Posts
    730
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Utility System
    This sounds like a large utility-scale PV system. In which case the utility requirements take precedence. This include low-voltage ride-through, supplying reactive power during a fault, operating under voltage droop. There are a lot of utility-grade protection requirements. You will need to review the technical section of the Interconnection Agreement to find out the specific utility requirements.
    e^(i pi) = -1
  4. #4
    Join Date
    May 2011
    Posts
    4,763
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by hhsting View Post
    No. Rapid shutdown is only required for arrays and DC wiring on or in buildings.
    Max DC voltage and operating voltage are irrelevant, at least once they're above the rapid shutdown threshold. AC voltage is irrelevant.
  5. #5
    Join Date
    May 2013
    Massachusetts
    Posts
    2,423
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If it is not on a building, rapid shutdown is not required. A free-standing framework for ground mount solar is not a building.
  6. #6
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,854
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Carultch View Post
    Although it is probably a structure.
  7. #7
    Join Date
    May 2013
    Massachusetts
    Posts
    2,423
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by GoldDigger View Post
    Yeah, and the definition of a structure is so vague that all I need to do is mortar two bricks together, and that meets the definition of a structure.
    There is an exception in 690.12 that excludes buildings whose sole purpose is to house equipment for a ground-mount solar array (like a shed for inverters, which would have uncontrolled DC conductors feeding in to them), so logically that would also exclude the structure of the ground-mount solar itself. The framework that mounts a ground-mounted solar array is only built for the purpose of the solar array.
    Carports are a gray area. I would expect them to not count as a building for the purposes of the 690.12 article, since it is a free-standing framework instead of what you usually think of as a building, but I have difficulty justifying it objectively with what the NEC gives me. All I need is a statement that buildings need walls to count as a building. The building definition references fire walls as the way that different sections of adjoining units will count as separate buildings, but no mention that walls are required to count as a building in the first place.
  8. #8
    Join Date
    May 2018
    Jamaica and london
    Posts
    1,101
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Gee... have seen many people in Jamaica using solar panels as the roofs of their car ports...thought it a great idea... wonder how we can create a roof that the roof is just solar panels anencephaly support frame?
    Student of electrical codes. Please Take others advice first.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
