Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 440V system voltage
  1. #11
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,054
    Quote Originally Posted by beanland View Post
    Check the dynamic range for the inverter, 440 is 10% below 480. If the inverter is rated for use at 480V +/-10%, then it should operate successfully at 440V. Check the manufacturer literature.
    Inverters are current limited so a 480V inverter operated at 440V will have a 10% lower kW rating.
    The other option is a boost transformer to change 440V to 480V. The are small for what they do.
    It may run at 440V but if the voltage dips even a little bit the inverter will go offline. I'd look at buck/boost transformers to center the voltage in the inverter's range; they aren't that expensive.
  2. #12
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    830
    Quote Originally Posted by mbrooke View Post
    ... break out a volt meter and measure.
    D'Oh!
  3. #13
    Join Date
    Jan 2011
    United States
    Posts
    7,978
    Quote Originally Posted by drcampbell View Post
    D'Oh!
    Only if you forget to put your leads back on volts... I've destroyed a few flukes like that
    I'm in over my head...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
