User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: PULLING WIRE
  1. #11
    Join Date
    Apr 2015
    phoenix az
    Posts
    262
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    depending on the location of stubs of course... if it ended up below busses or a mcb then that might be hard... we use a crane (usually) pull all runs then set the gear same day. of course we own the old crane...
  2. #12
    Join Date
    Dec 2016
    Royal City, WA
    Posts
    237
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by rambojoe View Post
    Ok you’re using a crane for construction......
    does the crane itself have its annual certification?
    does the crane operator have their crane operators certification?
    does the person connecting the load to the crane have their riggers certification?
    does the person giving the instructions to the operator have their signal persons certification?
    this applies to any crane is capable of lifting more than 1,000 lbs, and swings under power.
  3. #13
    Join Date
    Mar 2003
    New York
    Posts
    1,707
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Open ceiling. It's a substation house with slab and walls no Ceilings
    Sent from my SM-N960U using Tapatalk
    Then you can pull the wire and set the gear when it comes in.
    The gear can be adapted to a point at the factory to fit the footprint of the pipe.
  4. #14
    Join Date
    Apr 2015
    phoenix az
    Posts
    262
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dzboyce View Post
    sure dude. since you are the safety inspector and its such a valid question.. fly down to phoenix and verify these issues. I must warn you though, of my boss... do not waste his time, sir. why are you asking these questions to me?... it doesn't really help the op. what kind of crane do you think a electric company would have?! p.s.- it is a 1960's international that smokes like hell....
  5. #15
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    2,997
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Apparently contrary to many here, if I understand your question I have done it both ways. As I understand, the gear has an open bottom and you will merely set the gear on top of the conductors maybe feeding them through the bottom frame and out the front? Given the design of many pieces of gear, I have certainly opted to pull first. Often the required bending space per the NEC doesn't make it pull friendly.
    I know what I don't know, and I know where to go to find it!
  6. #16
    Join Date
    Sep 2012
    NJ
    Posts
    2,411
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Use a crane? For what? Pulling? How?
  7. #17
    Join Date
    Apr 2015
    phoenix az
    Posts
    262
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    well, a small flat bed with a crane on it... you drive it up by the service and have at it. of course its outside.. i tug it in 20' intervals and just do a safety hitch around the hook. most of the manpower is needed inside belaying the spools and guiding it in the hole. hell of alot better than using a (ahem) boom fork... or a tugger! then the crane flys the gear on the pad. alot of ways to slam in big cable but i have it down to a art. trust me on that. there is about a hundred ways to pull cable and drop gear I suppose, but only a few will not destroy 300' of 500mcm- that will make or break the job.
  8. #18
    Join Date
    Apr 2015
    phoenix az
    Posts
    262
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    and there are alot of ways to drop big gear- even when you cant get a hoist over it. or a 800lb motor... thats the fun of it, right? only a few ways will be successful...
  9. #19
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    2,997
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You use whatever you have, but mostly you have to use your brain. Two pulls that come to mind for me. I had to pull a long run of big copper out. We didn't have a sheave, so I pulled my truck with a rack on it up. Ran the rope and eventually the wire right up over the rack and hooked it to the ball of another truck and slowly drove away.
    My favorite though (all my idea), was a 500 foot run of 500KCMIL (MCM back then) It was on a Wemco reel, but the pull had to go through a ground box in the middle of it and the entire area was a mud pit. We set up a Lull (boomable fork lift) at the box with a 24" sheave. Set the tugger at one end and the reel at the other. We would tie off the rope at the tugger raise the Lull all the way up. That would pull wire in the first run of conduit, then we would lower the boom while pulling at the tugger end. Tie the rope off again and repeat. Eventually the wire came out of the first pipe up over the sheave and down in to the second pipe, where the tugger started to do work also. The genius If I say so myself) was that the wire didn't touch the ground and we didn't have to do something really difficult like lay down plywood and tarps to keep the mud off of the wire. My boss was quite impressed with my ingenuity.
    My point though is, think about the pull and use whatever you have that can be used safely.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
