User Tag List
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Mounting a Plastic Single Gang With Screws INSIDE of box
  1. #1
    Join Date
    Sep 2018
    coquitlam, BC, Canada
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Basically, I had to work in a condo and one of the boxes was mounted backwards in a tight section and already had wires spliced in it. This is a Loomex woodframe project with plastic boxes. To get the box properly oriented, I had to clip some of the plastic on the box. When I finally reoriented the box, I noticed that the side mount no longer had a place to screw it into a stud and since the wires were spliced I couldn't flip the box. So I put a screw inside of the box into the stud. I put some electrical tape over the screw, but I don't feel right about leaving it like this. The only thing I can think to do more is either
    A)pigtail the bond and bond the screw
    B)unsplice everything, throw the box away and replace it with a new box, possibly damaging the wire insulation in the process.
  2. #2
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    2,149
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's good that you feel bad about this. It shows you have character. That said, I think everybody has put a screw through a plastic box at least once in their career. For some people it's once a week. I wouldn't sweat it. (Now if it was a metal framed wall, that would be another story.)
  3. #3
    Join Date
    Feb 2013
    Mississippi
    Posts
    502
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Coppersmith View Post
    Well said
  4. #4
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,614
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    They have gone a little too far with rules here IMO. If that screw into wood framing should become energized - so what?
    Time to start installing bonding jumpers to wood framing I guess
    Maybe should bond the non metallic boxes as well.
    I live for today, I'm just a day behind.
  5. #5
    Join Date
    Feb 2008
    Texas
    Posts
    987
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have done work in old houses with crappy plaster or nasty drywall. I would always cut in my plastic old-work boxes near a stud, if at all possible, so that if the sheetrock or plaster started cratering I could screw the box to the stud for support.
  6. #6
    Join Date
    Feb 2007
    USA
    Posts
    5,814
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There is boxes made for this now.
  7. #7
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,255
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Put some duct seal and/or duct tape over the screw.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  8. #8
    Join Date
    Feb 2013
    Mississippi
    Posts
    502
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dennis Alwon View Post
    An electrician saying to use duct tape instead of electrical tape? Just picking on you
  9. #9
    Join Date
    Mar 2003
    Vermont
    Posts
    2,030
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sierrasparky View Post
    probably because so many of us did put a screw thru them....
    ~RJ~
  10. #10
    Join Date
    Mar 2003
    Vermont
    Posts
    2,030
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    By golly, there's actually a code for this! '17 changes inbold
    314.23 (B)(1) Nails and Screws. Nails and screws, where used as a fasten‐
    ing means, shall secure boxes by using brackets on the outside
    of the enclosure, or by using mounting holes in the back or in
    a single side of the enclosure
    , or they shall pass through the
    interior within 6 mm (1∕4 in.) of the back or ends of the enclo‐
    sure. Screws shall not be permitted to pass through the box
    unless exposed threads in the box are protected using
    approved means to avoid abrasion of conductor insulation.
    Mounting holes made in the field shall be approved.
    ~RJ~
Posting Permissions
  • You may not post replies
  • You may not edit your posts
