User Tag List
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Look up.
  1. #1
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    10,290
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Look up.
    Customers maintenance called and was starting the standby generator and needed help getting thins running again. His fellow employee(s) had lifted a sunshade up into the primary serving the feedlot. No one killed or hurt but it shut down that section of distribution.
    Feelot sunshades are BIG.
    Dont forget to look up occasionally.
    Tom
    TBLO
  2. #2
    Join Date
    Jul 2006
    Posts
    8,232
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Saw a painter do something similar in getting a long extension ladder off of his truck rack. He parked under the primary 12kV service drop and tilted the ladder up into the wires, probably nicking the old insulation and caused a flashover. Nobody hurt, but I think the painter wet himself!
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  3. #3
    Join Date
    Dec 2015
    Yakima, WA
    Posts
    182
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Had some gravel delivered this morning to my house. Last truck had about 1/2 yd left and was to dump it at the back of the property. Turned around as i heard the hum of arcing electrical to see he had lifted his bed and ran into the overhead lines. Tore down a pole before he realized what happened
  4. #4
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,806
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Been a couple years ago I think, but a farmer had boom of a sprayer contact 69kV line. Was smart enough to stay in the machine until they told him it was safe. 69kV is usually high enough elevation this won't happen, somehow he found that one spot that was lower.
    I live for today, I'm just a day behind.
  5. #5
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,246
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MattS87 View Post
    ...and this is why, when I have a contractor do work at my house, I ask to be listed as an additional named insured on their policy.
  6. #6
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,806
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gadfly56 View Post
    Building an addition, I can see that. Having them come for a 1 or 2 hour fix it project, probably not happening. The mentioned gravel delivery truck may likely been simply a delivery truck from a sand and gravel company and not a contractor doing any work on the premises.
  7. #7
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,246
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    Fair enough.
  8. #8
    Join Date
    Dec 2015
    Yakima, WA
    Posts
    182
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yep just a delivery. Where the lines are is well enough away from anything of value on my property luckily. Got some nice burn marks in the grass though
  9. #9
    Join Date
    Oct 2018
    Hamburg, Germany
    Posts
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wow
    It's really interesting hearing such amazing and kind of scary stories.
    I've just recently stared being more interested in this field, and i haven't ever had anyone tell me anything like you people have. Its really amazing.
  10. #10
    Join Date
    Feb 2012
    Athol, ID
    Posts
    828
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Jraef View Post
    Just a comment.....12KV overhead primary is not insulated, so if he got into the primary, it meant mucho smoke!. Service drops will be insulated, but never depend on insulation to keep you alive. Look up, then look up again in case you missed something! Had a TV crew raise an antenna into 12KV. Nobody killed but the TV truck ignited and was a total loss. Just outside the substation, so fault current was significant!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
