User Tag List
Results 1 to 6 of 6
Thread: Light in decontamination room - hospital
  1. #1
    Join Date
    Jun 2007
    Posts
    784
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Does light install in in decontamination room - hospital
    need to be wet location listed and enclosed or have
    any specific requirements? This room is located by the
    ER entrance where they brought the patient in.
  2. #2
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,700
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    No clue what goes on in that room. More information is needed.
    -Hal
  3. #3
    Join Date
    Mar 2003
    New York
    Posts
    1,908
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    What is in there now?
    From what I have been told the floor gets wet from spilled water, nothing special.
  4. #4
    Join Date
    Dec 2010
    Posts
    1,496
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    From
    https://www.michigan.gov/documents/B..._150922_7..pdf
    For routine patient decontamination needs the hospital shall provide
    decontamination facilities that minimally includes the following building elements:
    1. An outside entrance and internal door to a corridor of the emergency department.
    2. All sanitary waste (sink, floor drains) shall discharge to a dedicated holding tank.
    3. A negative air environment, exhausted at least 25 feet from exterior doors, operable
    windows, or domestic air intakes.
    4. A hand held showerhead with temperature controls.
    5. The decontamination area ceiling, wall, and floor finishes shall be smooth,
    monolithic, nonporous, non-adsorptive, and scrubbable, (capable of withstanding
    cleaning with and exposure to harsh chemicals.) Floor finishes shall be non-slip.
    The recent emphasis in mass decontamination has overshadowed the traditional needs
    that hospitals have for occasional decontamination of a more limited number of
    individuals. Obviously the needs, level of care, and regulations of contamination victims
    change from field conditions to those patients in hospitals.
    State licensed and federally certified facilities and hospitals come under a number of
    government regulations. These regulations include the need to protect patient rights
    (privacy and dignity) and their general well being as well as the health and safety of staff
    and the public. Voluntary accreditation guidelines may add further standards.
    The decontamination area must be sealed and cleanable as noted above. The ability to
    keep the room “seamless” will eliminate contamination and prevent moisture damage.
    Provide wet location light fixtures and place light switches outside the room.
    The more they overthink the plumbing, the easier it is to stop up the drain
  5. #5
    Join Date
    Mar 2003
    New York
    Posts
    1,908
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Dkidd, nice is he in Michigan? If not I would suggest he try to find a similar document as you have provided for his location.
  6. #6
    Join Date
    Dec 2010
    Posts
    1,496
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sameguy View Post
    GIYF
Posting Permissions
  • You may not post replies
  • You may not edit your posts
