User Tag List
Results 1 to 2 of 2
Thread: Conn New & Extg. Conduit
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,540
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    See pics. There are existing underground concrete encased empty conduits that dead end between 20 and 60' before the new structure going up. We are to extend those existing conduits. The detail says there is a coupling( theY are PVC pipes) where it ends. So I'm thinking there is a little piece of pipe sticking out past the concrete encasement with a coupling attached or when they say coupling could it be the belled end? So if it's either a coupling or belled end when attached the new piece to the existing pipe there wouldn't be a fitting required correct? We could just push pipe on? Thanks.
    Also another thought nothing is excavated past the exisiting duct bank and they need to excavate for our new conduits I would think that could pose a problem for the esting pipes maybe being damaged but I guess there is some sort of identifier for where the existing duct bank ends. Thanks.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	21267   Click image for larger version.
  2. #2
    Join Date
    Mar 2003
    New York
    Posts
    1,870
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    It's in your thumbnails
    Guy with a shovel
Posting Permissions
  • You may not post replies
  • You may not edit your posts
