User Tag List
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 26
Thread: Coupling?
  1. #11
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,623
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    So looks like pvc. Looks like a coupling where it connects to box but you wouldn't use that? What is it? Male Adapter? Thanks
    Sent from my SM-N960U using Tapatalk
    Off topic but sure looks like whatever is inside that box might be very crowded. Might be code legal if all under 4 AWG or is communications cables or something, but likely still very crowded.
    I live for today, I'm just a day behind.
  2. #12
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,962
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by WarrMann View Post
    Yes. All you need is the "terminal adapter" which is the same thing as a threaded male connector for pvc at any supply house.
    Im not a fan of the threaded coupling outside the box and screw a connector into that to secure it method. Just use a threaded connector, that's all you need if you line your conduit up square to the box
    Sent from my SM-G950U using Tapatalk
    The box adapter we are referring to glues into a coupling.
    "Electricity is really just organized lightning." George Carlin
    Derek
  3. #13
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,405
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by jumper View Post
    Sent from my iPad using Tapatalk
    Brought to you by Carl's Jr.
  4. #14
    Join Date
    Sep 2012
    NJ
    Posts
    2,412
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So what is this piece?
  5. #15
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    4,405
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Butt the coupling to the KO, and this piece inserts through the enclosure into the coupling. The lip holds the conduit to the enclosure, and you now have a flush entry instead of threads coming up.
  6. #16
    Join Date
    Sep 2012
    NJ
    Posts
    2,412
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by brantmacga View Post
    Ah so that piece get installed from the inside of the enclosure? Thanks.
  7. #17
    Join Date
    Sep 2016
    Atlanta, GA
    Posts
    147
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Huh! I've seen something like that a few times, but I always thought some guy just rigged something up with a reducer or something like that. It looks like it makes a pretty good "mechanical" connection when that glue dries.
    I'm guessing they cost a few more dollars than a connector and locknut for the larger size conduits?
  8. #18
    Join Date
    Sep 2012
    NJ
    Posts
    2,412
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So this piece and the coupling shown could be what's used in the pic I posted?
  9. #19
    Join Date
    Jan 2009
    Posts
    15,962
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Maybe. Cannot tell from pic, it will be one of the two methods.
    I would guess that those are terminal adapters and locknuts used in your pic.
    Derek
  10. #20
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,194
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    They also come in handy if you have the nose of an LB that is right against a cabinet, with no room to add a TA.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
Posting Permissions
  • You may not post replies
  • You may not edit your posts
