Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Coupling?
  1. #21
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    38,252
    Quote Originally Posted by electrofelon View Post
    They also come in handy if you have the nose of an LB that is right against a cabinet, with no room to add a TA.
    I have used them that way more often than with a coupling.
  2. #22
    Join Date
    Jul 2005
    Posts
    858
    Wait....how do you know it's not a PVC female adapter with a threaded chase nipple?
  3. #23
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,219
    Based on appearance of how short it is relative to its width, I'm going with it being a male adapter and a lock ring inside.
    A female adapter would be as long as a coupling, and probably have ribs on the threaded end.
  4. #24
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    2,763
    Quote Originally Posted by brantmacga View Post
    But you can also use a coupling with a terminal adapter on the inside. It gives you a flush smooth entry.
    Sent from my iPad using Tapatalk
    As electrofan says, it is a box adapter and I just found something out the hard way. The metal of a box is too thin for a box adapter to seat all the way down on a coupling, so the termination is loose by about 3/16" Sucks, and it happened at my own house!
    I know what I don't know, and I know where to go to find it!
  5. #25
    Join Date
    Sep 2012
    NJ
    Posts
    2,238
    Ok..so obviously a few different ways to terminate pvc to a metal/steel box.
  6. #26
    Join Date
    Mar 2003
    Vermont
    Posts
    1,749
    Those strut clamps might be a bit of a dispute.....~RJ~
Posting Permissions
  • You may not post replies
  • You may not edit your posts
