User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Odd doorbell failure
  1. #11
    Join Date
    Mar 2003
    New York
    Posts
    1,817
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    And that's why I have door knocker!
    Ok, camera doorbells.
  2. #12
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    7,656
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    181004-0858 EDT
    gsurace:
    You indicated you have at least a voltmeter, because you said the transformer is OK. Make use of that instrument to do your troubleshooting. You should know how to do that.
    CAT 5 should not be used for this type of application. It is not a rugged cable. In an expensive home it should be replaced.
    You have not described how the circuit is wired. Are separate cables run from each button back to the chime and transformer? Where is the transformer located? Provide a drawing of how you think the circuit is wired, and the layout.
    Are the buttons wired in series? If so, then should not work. Does each button go to a different chime? Is one cable daisy chained to the two buttons?
    What are voltages measured at different points in the circuit with no buttons pushed, each different button pushed, both buttons pushed, for both working and nonworking conditions? What is transformer no load voltage, and when chime is chiming?
    The information you provided is far too little for any remote person to give you much help.
  3. #13
    Join Date
    May 2018
    Jamaica and london
    Posts
    1,306
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cat 5 is run in newer homes sometimes because of how many people want a video doorbell... they then change it after a while to a normal doorbell, or a normal doorbell is installed with the plan to install a video doorbell... my own home has a conduit run in for the doorbell..lol.. ott according to my wife.
    Student of electrical codes. Please Take others advice first.
  4. #14
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,436
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    No. CAT5 is run because that's what is on the truck and stocking other cables might cost money.
    Don't know what those guys are going to do when CAT5 is not stocked anymore (like CAT3) and replaced with CAT7 or something that is impossible to work with. That's what you get when you borrow from the data world.
    -Hal
  5. #15
    Join Date
    Oct 2013
    newburgh,ny
    Posts
    471
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Double up
    Double up the wires. Voltage drop on cat 5 with a door bell only using one set of wires is just asking for headaches in my opinion.
    Also tightening one should not bring on both lights if wired front and back, even if both are wired for front one should not light the other unless they end up in series somehow.
    What happens when both are pressed at the same time?
  6. #16
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,147
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by just the cowboy View Post
    See post #7
    If you aim at nothing, you will hit it every time!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
