User Tag List
Results 1 to 5 of 5
Thread: Is Bonding required?
  1. #1
    Join Date
    Oct 2018
    Florida
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have rooftop mounted HVAC Units in a building in Florida. The HVAC units are mounted on aluminum brackets. Do the brackets have to be bonded to the HVAC equipment? I reviewed NEC 250.110 and 250.112 but still not sure if this qualifies under any of those sections. Please advice. Name:  7GkGlXmp1JRBI50Hf8hVFtflrsnx8iLu2Vpu3byS140=.jpg
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,852
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    IMO no, they're already bonded by the connection to the unit.
    Welcome to the Forum.
    Rob
  3. #3
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,962
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    Maybe. Often there are rubber and cork pads under the unit for vibration and the unit is semi- loosely bolted down.
    "Electricity is really just organized lightning." George Carlin
    Derek
  4. #4
    Join Date
    Jun 2017
    WI, USA
    Posts
    389
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    They need to be of equal potential if their is a chance they could become energized.
  5. #5
    Join Date
    Oct 2018
    Florida
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks.
    Thank You. So what i gather from the replies is that if the units are mounted directly on the aluminum strut they do not require additional bonding. If they are mounted using rubber pads or any other insulation material, they may require bonding?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
