Page 13 of 13 FirstFirst ... 3111213
Results 121 to 130 of 130
Thread: Units of measurement
  1. #121
    Join Date
    May 2018
    Jamaica and london
    Posts
    775
    I tell you.. 45 mm is easier to find than 1-11/16ths inches... at least for me...
    Student of electrical codes. Please Take others advice first.
  2. #122
    Join Date
    Jul 2013
    Resting under the Major Oak UK
    Posts
    1,207
    Quote Originally Posted by ggunn View Post
    So was our method of timekeeping.
    It caused some confusion.
    This clock is on Bristol corn exchange. The first minute hand is Bristol time, the second minute hand is GMT.
    The reports of my death are greatly exaggerated.
  3. #123
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,049
    Quote Originally Posted by Tony S View Post
    But coordination of railroad schedules is what drove the establishment of time zones rather than having each locale calibrate their clocks to solar time.
  4. #124
    Join Date
    Jul 2013
    Posts
    1,207
    There is one standard of weight used the world over, the troy ounce. One troy ounce = 1.0971 Avoirdupois ounce or 31.1034 grams.
    1 Troy pound = 12 troy ounces.
    Used for bullion transactions.
  5. #125
    Join Date
    May 2012
    Boca Raton, Fl, USA
    Posts
    1,082
    Tony...
    Sorry, but multiplication by constants must be used in a certain direction to convert kg to oz(t)! For example you can't go the short way from kg -> lb (avoir'), lb(avoir') -> lb(t), lb(t) -> oz(t), using just 3 constants !
    Instead, multiplication must go from kg -> g, g -> mg, mg -> scruple, scruple -> pennyweight, pennyweight -> dram(t), dram(t) -> oz(t) (requiring 7 constants)!
    Let me know if there is a need know the multiplication constants (5 have no decimals, one has 1 decimal, and 1 has 5 decimals)!
    Regards, Phil Corso
  6. #126
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    23,515
    Quote Originally Posted by MAC702 View Post
    Using the dark side:
    "Luke, I am your ruler!"
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  7. #127
    Join Date
    Mar 2003
    New England
    Posts
    13,440
    I'll give up imperial when you pry it out of my cold, dead hands.
  8. #128
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    828
    Progress is sometimes achieved slowly -- one funeral at a time.
  9. #129
    Join Date
    May 2009
    Usa
    Posts
    1,571
    Quote Originally Posted by Besoeker View Post
    I know I have brought this topic up before.
    Will the US ever join the rest of the world and move to using SI units of measure?
    For example, is there any sense in two different units for power?
    And AWG is baffling in its derivation.
    https://en.wikipedia.org/wiki/American_wire_gauge
    Works great here. Why change it? Maybe the rest of the world should adopt our standards.
  10. #130
    Join Date
    Mar 2003
    New England
    Posts
    13,440
    Quote Originally Posted by chris1971 View Post
Posting Permissions
  • You may not post replies
  • You may not edit your posts
