Originally Posted by
Adamjamma
ok, just me asking, but how does he consider the wires secured within 12 inches? By going through the hole in the stud? And the bend is too tight as well...lol
And even I know that the box is overfilled, but what gets me as well is trying to figure out his numbering system. I number based on breakers, and then use letters for light switch circuits, but all numbers to a circuit should match... it looks like he just put a bunch of numbers on wires since he was told to label stuff...lol...maybe he was listening to a car race that day...
You think that particular installer was concerned about securing within 12 inches?
mbrooke
They are flimsy and typically associated with DIY and trunk slammer work- much like tape around wire nuts. Never seen a pro use Carlon unless perhaps its their heavy duty version and it was never in a new build.
I sort of had that approach for some time about them. I still don't like the multi-gang boxes and try to avoid them as much as possible, but single gang 18 cubic inch - is cheap at big box store, and not really much flimsier than any other plastic box, if you want a fairly rigid box (which is more critical with multi-gang) then you should be looking at fiberglass or other more expensive plastic boxes.
I live for today, I'm just a day behind.
Bookmarks
