User Tag List
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: HI_RISE ac compressors on roof 100 apts
  1. #1
    Join Date
    Jul 2013
    fort lauderdale, florida
    Posts
    74
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi everyone,
    question i have to run power and low voltage for 100 apts on a new building 10 stories, i was going to run a 1/2 for L.v. and 3/4 emt from each apt to roof but i will end up having 200 conduits on roof for this compressors, any ideas on how to get power from each apt. to roof.
  2. #2
    Join Date
    Jan 2011
    United States
    Posts
    8,505
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by tico17 View Post
    Hi everyone,
    No magic pak?
    http://www.magic-pak.com/landing/v-s...SAAEgK98PD_BwE
    I'm in over my head...
  3. #3
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,228
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Probably the reason you never see anything like that. Usually the building has a chilled water system for A/C that is included in the common charges. +
    ... Or packaged units.
    -Hal
  4. #4
    Join Date
    Oct 2015
    US
    Posts
    824
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    each unit has its own condenser on the roof I find that hard to believe 100 units on the roof would take up quite alot of space
    Sent from my SM-G950U using Tapatalk
  5. #5
    Join Date
    Jul 2013
    Posts
    74
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by nickelec View Post
    Yes, first time seeing this, usually is a cooling tower here in s. Florida, I guess I have no choice to run separate conduits. I was thinking of sharing power for t. Stat and 208v using same type of wire conductors
    Attached Images Attached Images
  6. #6
    Join Date
    Oct 2015
    US
    Posts
    824
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Can you run one conduit per floor maybe how many app on each floor and how big are the units
  7. #7
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,614
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mbrooke View Post
    Your link shows the inside air handling units, OP has 100 outdoor units being placed on same roof, which only has 10 units per floor, you would think they will be a little crowded up there.
    I can't imagine what this will cost, that is a lot of tubing and refrigerant to get from roof to units on the bottom level. Not even sure if compressor is rated to pump through such long circuit without derating and/or increasing line sizes to compensate for losses - which makes even more refrigerant necessary.
    Owner probably thinking they are saving $$ and wanting a circuit from each tenant space to their respective cooling unit so they don't pay the energy bill. Though they are putting a small fortune in the initial investment, and depending on how tenant/leasing agreements work out, maybe still going to have a lot of maintenance cost down the road compared to a system more suited for the application.
    I live for today, I'm just a day behind.
  8. #8
    Join Date
    Feb 2016
    Illinois
    Posts
    1,296
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kwired View Post
    I agree. This setup is crazy.
    Maintenance will be a nightmare.
  9. #9
    Join Date
    Jan 2011
    United States
    Posts
    8,505
    Mentioned
    0 Post(s)
    Tagged
    1 Thread(s)
    They also contain a compressor and coil- all in one. Thats how they do it around here in high rise when there isn't a central chiller or boiler room.
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    39,614
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, I didn't look close enough. Still need to have something to the exterior to get rid of heat during cooling mode or to take in heat if they have reversing valve to use as a heat pump.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
