User Tag List
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: NC Dept of Insurance Official Interpretations
  1. #1
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,598
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    If anyone wants a copy of NCDOI official interpretation of some commonly disputed sections in the 2017 NEC then click on the link below. I advise you to download it into word and the links should work. The links just take you to other areas of the document. Move your mouse to the link then use ctrl and click to activate the link.
    NCDOI Formal Interpretation
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,232
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Dennis that's for the 2017 NEC? I think that you had a typo in your post.
    Rob
  3. #3
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,598
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    Why didn't you fix it? lol
    Thanks I got it
  4. #4
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,232
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dennis Alwon View Post
    Thanks I got it
    I found this question and answer interesting:
    Question 2:
    If a metal underground water pipe is used as part of an electrode system and is supplemented with a ground rod, is another grounding electrode required to supplement the supplemented ground rod?
    Answer 2:
    No. The requirement of section 250.53(D)(2) requires one supplement electrode of a type chosen from sections 250.52(A)(2) through (A)(8), in which a rod is listed in section 250.52(A)(5).
    Both the water pipe and the rod must comply with the installation requirements of section 250.53(A). Because the water pipe and the rod make two electrodes, each supplement the other; thus, 250.53(A)(2) is satisfied.
    Rob
  5. #5
    Join Date
    Feb 2003
    Minnesota
    Posts
    7,094
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question 2:
    Answer 2:
    Oooo. I LIKE it.
    Another Al in Minnesota
  6. #6
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,232
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Not sure how a water pipe is supplementing a single ground rod when the water pipe gets changed to plastic.
    Rob
  7. #7
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,598
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    It's not, in fact, the rod is really only supplementing the water line specifically for that reason. When the electrode becomes plastic then the rod is still there. So technically if they change the copper pipe to plastic then one should have to add another rod.
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,232
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Exactly that's why I disagree with their response to the question unless the single rod is 25 ohms or less.
    Rob
  9. #9
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,598
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    The install is correct but there seems to be a disagreement as to the explanation. Is that how you see it.
  10. #10
    Join Date
    Jun 2003
    Posts
    11,097
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I thought we’re werent supposed to worry about future ‘what ifs’ ? We would never get done.
    Tom
    TBLO
Posting Permissions
  • You may not post replies
  • You may not edit your posts
