Results 1 to 7 of 7
Thread: Sub Instll
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,271
    Sub Instll
    Like others feedback. Once these are set on pad how many guys and how many days do you think it would take to attach the 5kv, xfrmr and 600v sections together. No feeders terms!! It will be three separate section. I'm thinking 4 guys 4 days. Thanks
    Attached Images Attached Images
  2. #2
    Join Date
    Mar 2003
    New York
    Posts
    1,404
    Will it fit through the door or needs to be stripped?
    Do you have the tools to move it? Get it off on he truck? Get it in the building?
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    2,271
    Quote Originally Posted by sameguy View Post
    Open slab on grade in field. Will be set on pad by rigger and we will skate in place...not much moving.
  4. #4
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,147
    So basically it's just bolting together 2 sections and the transformer? 2 men 2 days.
    Rob
  5. #5
    Join Date
    Sep 2012
    NJ
    Posts
    2,271
    Quote Originally Posted by infinity View Post
    Bolting a bunch of bus bars together. 2 men 2 days, that's all?
  6. #6
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,147
    Quote Originally Posted by mstrlucky74 View Post
    Depends on how skilled your electricians are.
    Here's a 750kva, about 7500 pounds, 4160-208/120 substation. Moved 100' around obstacles, set on the pad and bolted onto one 208/120 volt switch section which was also moved about 100'. 2 men, 1 day (Journeyman and Apprentice). Once it's on the pad we just drop it onto several 3/4 RMC rollers and move it with a pinch bar.
    Click image for larger version.
    Rob
  7. #7
    Join Date
    Jul 2005
    Posts
    865
    I came up with 69 m/h....you are right on
Posting Permissions
  • You may not post replies
  • You may not edit your posts
