If you're alternating the devices on two different zones then it appears that you're carrying both zones through out the entire loop. There is probably a better way to do this requiring less cabling. If you want to use your method as a worst case scenario for estimating purposes that would be good but you might be able to change the loop layout in the field and use less cable.
