User Tag List
Results 1 to 6 of 6
Thread: PG&E Ag rate schedules for Solar
  1. #1
    Join Date
    Sep 2015
    Merced, CA
    Posts
    15
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am wondering what everyone else uses for customers who are on AG-4B or AG-5B that install solar?
  2. #2
    Join Date
    Oct 2007
    New Jersey
    Posts
    6,329
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gporter85 View Post
    "Uses" in what sense? Panels? Inverters? Something else?
  3. #3
    Join Date
    May 2011
    Posts
    4,866
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by gadfly56 View Post
    When you go on Net Energy Metering you have the opportunity, or you are required, to pick a different rate schedule. He's asking what others consider the most advantageous rate schedule to go on if you have solar.
  4. #4
    Join Date
    Sep 2015
    Merced, CA
    Posts
    15
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jaggedben View Post
    Exactly. Is there a clear favorite rate schedule?
  5. #5
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,950
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    The profile for power delivery from solar is pretty predictable once you know the orientation of the array(s), but that will vary from customer to customer. The big individual customer factor is what the load profile is like. (Working couple with nobody using A/C at home during the day, stay at home mom or dad with A/C on all the time in summer, etc.)
    You can figure out which rate schedule is best for a particular combination, or you can say which turns out to be the best most of the time to avoid having to do the actual analysis.
    It may be possible to rule some of them out right at the start, though.
    One problem is that, AFAIK, POCO can keep the same nominal rate schedule but still later change the start and end times for the off-peak, near peak and peak rate periods.
  6. #6
    Join Date
    May 2011
    Posts
    4,866
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know the answer, because I haven't worked on ag sites. If you want to do your own analysis, I understand that Energy Toolbase is the thing for that. Golddigger is right that to he most diligent you'd run an analysis for each customer. Of course, I realize that some don't care enough to give you the data you need to do that.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
