User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Conduit supports on metal roofs
  1. #1
    Join Date
    Oct 2018
    Massachusetts, MA
    Posts
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you are installing IMC conduit for PV DC source circuits for long runs on a large standing seam metal roof (commercial), should you use conduit support straps that allow the conduit to move within the strap (for thermal expansion/contraction) if the support is attached to the roof via a standing seam clip, or should the strap be tight fitted so that there is no movement allowed (assuming the conduit and the roof expand/contract at the same rate)?
  2. #2
    Join Date
    Nov 2015
    CA, USA
    Posts
    734
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Shouldn't the movement be allowed for by using conduit expansion joints? NEC 342 requires that IMC be securely fastened but does not say anything about allowing for expansion. Unlike PVC where it calls out the requirements. It's up to the contractor to determine if expansion will be an issue and plan accordingly.
  3. #3
    Join Date
    Jan 2018
    SE Michigan
    Posts
    125
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You might want to consider a support block type. Allows for slight movement and no roof penetrations. Keeps it above the roof so it runs considerably cooler.
    http://www.eaton.com/us/en-us/catalo...-supports.html
    https://www.cableorganizer.com/arlington-industries/roof-topper-conduit-support/
    https://www.mifab.com/Catalog/C-PORT_Roof_Pipe_Supports
  4. #4
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    2,026
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by pv_n00b View Post
    Shouldn't the movement be allowed for by using conduit expansion joints? ...
    Expansion joints eat up and release conduit as it expands or contracts. They don't help its displacement relative to the roof surface. Or am I picturing the question wrongly?
  5. #5
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    15,966
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    See 300.7(B) and the Index for other applicable code sections.
    "Electricity is really just organized lightning." George Carlin
    Derek
  6. #6
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    5,330
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by JpSolar View Post
    IMO no expansion joint is needed. Not only is the IMC and roofing the same material so it will expand at the same rate, the standing seem clips will have plenty of flex anyway.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  7. #7
    Join Date
    May 2013
    Massachusetts
    Posts
    2,454
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MAC702 View Post
    On a related note about thermal expansion planning. A lot of PV rail systems specify expansion joints, yet rigidly fasten each support point to the structure below. It would appear that this doesn't allow the expansion joint do its job, if the run is only able to freely expand and contract in one span length, while 9 spans out of 10 are rigidly bolted at both ends.
    Yes, standing seam systems can flex a little at each L-foot/attachment, but systems rigidly bolted to a beam system or rafters cannot do the same.
    Does anyone else understand how this is supposed to work?
  8. #8
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    2,026
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by electrofelon View Post
    ...Not only is the IMC and roofing the same material so it will expand at the same rate...
    I would not have expected that. There is a small difference in the type of steel used, but there is a huge difference in material shape and volume or cross-section, and a huge difference in heat sinks.
    Steel roofing seems to be completely fastened to prevent any expansion movement. My limited experience with steel roofing is residential, and it's simply screwed down every couple feet.
  9. #9
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,765
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Some larger metal roofs are secured with "T" shaped clips that allow the roof to move through them as it expands and contracts. They are troublesome to mount solar on because you cannot put an S-5 clip on top of or very near a roofing clip because compressing the seam at that point can restrict the movement of the roof.
  10. #10
    Join Date
    Nov 2015
    CA, USA
    Posts
    734
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    In theory, the conduit mount can take a certain amount of force from the expansion and contraction of the conduit without movement or damage. When the amount of force exceeds a given point the mount will be damaged or pulled out of the roof. The amount of force due to expansion is related to the length of the conduit and the temperature change. The temperature change and length of the conduit run will dictate the number of expansion joints required. The NEC does not provide a table for IMC so you have to do it on your own. You can get the expansion in length per deg from the conduit manufacturer. The NEC does not give a requirement for how much change in length is allowed for IMC, but the 1/4" given for PVC is probably not a bad number or get a number from the conduit mount manufacturer.
    To bring it all together, get a temperature change range for the site, using that and the change in conduit length per deg, find the length of conduit you can have where you get maximum change in length you are designing for. That's the longest straight run you can have before you put in an expansion joint.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
