User Tag List
Results 1 to 8 of 8
Thread: Box for the Low Voltage jacks
  1. #1
    Join Date
    Sep 2013
    Sunrise, FL USA
    Posts
    5
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Does the NEC code allow Plaster rings without a box, in a drywall wall in a commercial building?
  2. #2
    Join Date
    Feb 2007
    USA
    Posts
    5,847
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    why not. There are listed such devices.
    The only caveat is if it is a fire rated wall or the designer specifies other for reasons as sound or draft.
  3. #3
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,438
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    I think that is a building code and not an NEC issue. Unfortunately, I do not know the answer
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  4. #4
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have seen plaster rings screwed directly to the stud on interior, non-rated (the wall between the bathroom and bedroom in a hotel for example) walls for thermostats... We never use open back boxes or LV-1 boxes in commercial though, most walls in hotels are rated for fire and sound, and since 95% of our devices or in those walls, or ceilings, you must use a full or closed back box in those cases
    You would need to look at the listing/instructions of the plaster ring to see if screwing it to the stud is permissible by 110 3B. Also have a look at 300.21. the rest of it would be in your local building codes.
  5. #5
    Join Date
    Jul 2017
    Lynnwood, WA US
    Posts
    8
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Building code/Energy code often comes into play on exterior walls. Fire rated walls also make open rings not usable but otherwise ok to my knowledge.
  6. #6
    Join Date
    Dec 2010
    Tennessee NEC:2017
    Posts
    5,147
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Are you guys calling these plaster rings?
    If so, they are not called plaster rings, they're called low voltage brackets. A plaster ring goes on a box.
    If you aim at nothing, you will hit it every time!
  7. #7
    Join Date
    Jul 2003
    New Jersey
    Posts
    27,124
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Plaster ring.
    Here's another thread. Please do not post the same question twice.
    http://forums.mikeholt.com/showthread.php?t=194491
    Rob
  8. #8
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,436
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Old work and new work. I use the "brackets" (actually Caddy MPLS) for cut-in work. For new work I use a plaster ring or the Caddy MP1S (shown in that other thread). Plaster rings are cheaper.
    -Hal
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
