inspectorjoe
- Dover, NH USA
in 680.25 (pool feeders) the exception has been removed. so if I understand this right, does it now say that you would not be able to install feeders unless you change your SER from meter disco to panel? see below the part removed.
Exception: :angel:]A feeder within a one-family dwelling unit or two-family dwelling unit between remote panel board and service equipment shall be permitted to run in flexible metal conduit or an approved cable assembly that includes an insulated equipment grounding conductor within its outer sheath. the equipment grounding conductor shall comply with 250.24 (A) (5)
