User Tag List
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 45
Thread: Pulling Heads
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Pulling Heads
    I know our guys always use pulling heads and don't make up their own but is one more advantageous over the other? Thanks.
    https://www.youtube.com/watch?v=OAK0wq4agxM
  2. #2
    Join Date
    Feb 2009
    NY
    Posts
    1,567
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I’m old school, I think making a head up takes more stress before ripping apart, which is rare if head made correctly.
  3. #3
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For that size wire, that is a great method. For smaller wires, Kellum grips are faster.
    For pulling com wire, where you will have multiple pulls through the same wire tray or other supports, taping the wires together then putting a single half hitch knot or choker, on to the pull string then taping that to the lead is the fastest way to rig wire and leave another pull string in play. That knot is not very secure, however you're not supposed to exceed 25 lb pulling force on twisted pair and small coax cables, so they work fine.
  4. #4
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,613
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    We buy all of our large conductors with the heads already attached. Since our labor cost is very high it ends up being much cheaper to pay someone to put them on before the reels hit the job site. Also our failure rate for the crimped on heads is zero.
    Rob
  5. #5
    Join Date
    Jul 2005
    Posts
    886
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Are those reusable?
  6. #6
    Join Date
    Sep 2012
    NJ
    Posts
    2,359
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    Makes a lot of sense! So they are garbage after that reel is pulled and heads are attached to each and every reel you order/pull?? Thanks.
  7. #7
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,264
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cdslotz View Post
    Are those reusable?
    Nope.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  8. #8
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    24,264
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mstrlucky74 View Post
    Yep.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  9. #9
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,613
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Yes they're not reusable and we order the conductors with them already attached. I believe that they're only about $100 per reel.
    Rob
  10. #10
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is that $100 per lead/head?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
